tranny noise?
Old Nov 22, 2006 | 02:31 PM
jtvrba's Avatar
Default tranny noise?
Hey guys just a quick question, maybe you've run into this before....
My 850 runs like a top now, except for the rear seal leak....
When I put the car into drive/reverse, the engine compartment makes
a louder sound. Almost like a rattling exhaust pipe....As soon as you take it out
of gear the noise goes away. In park I can rev the engine and no noise.
Old Nov 22, 2006 | 10:17 PM
JPN's Avatar
JPN
Default RE: tranny noise?
Greetings from Chicagoland.
Just a guess, but have you checked the engine mounts? The pax-side mount gets weak before other mounts do. When the tranny is engaged, the engine is under load and may get "twisted" a little, and engine might be rubbing against the sub-frame.
Take a look at FCP Groton's parts illustration. The part #9135178 is what I'm referring to (in fact, I just replaced it a few days ago).
http://www.fcpgroton.com/volvo850mounts.htm
The mount actually has a wear indicator. There is a probe sticking out of the holes on the side. If the probe is low (closer to the sub-frame), you need to replace it.
If this isn't the case, have someone look at the engine compartment while you shift into gear (use park-brake and wheel chocks to avoid running over the person).
Best wishes,
JPN
Block91
2001-2013 model year V70
23
Apr 3, 2020 09:53 PM
Ric6Lew
Nov 9, 2013 01:12 PM
schmuecker
Jul 10, 2013 10:26 AM
zerochills
Aug 19, 2009 08:01 PM
ludeless
Aug 28, 2007 07:14 PM
