Noise from front end/motor/ tranny ???
Old Aug 4, 2009 | 10:01 AM
zerochills's Avatar
Default Noise from front end/motor/ tranny ???
i have had a noise for a while coming from the front of the vehicle, only detectible when sitting at idle (first starting vehicle, stop light, etc.) its sort of a rattle, knocking around noise, not real faint but not real terribly load either. motor mount? motor? tranny?
Thanks
Old Aug 4, 2009 | 12:03 PM
850tony's Avatar
might just be a lose exhaust heat shield
Old Aug 4, 2009 | 07:45 PM
Bad engine mount?
Old Aug 19, 2009 | 01:29 PM
zerochills's Avatar
Default specification
engine mount may sound correct. i failed to specify in my original post that this is only noticable while it is in gear, if i place into nuetral the signs stop.
how would i go about rplaceing and/or diagnosing an engine mount.
thanks
Old Aug 19, 2009 | 08:01 PM
3 out of 4 on most cars are rubber and you can see them.
You can usually just inspect them and see if they are broke.
It sounds more like mounts if it only happens in gear.
Wing0
Dec 13, 2013 02:39 PM
scartydog
Jun 23, 2006 05:25 PM
Virginia Girl
Jun 14, 2006 10:42 AM
cbatterman
May 10, 2006 12:00 AM
ZIGZAG
Mar 17, 2006 09:34 PM
