tranny shifts hard
RE: tranny shifts hard
If you know of someone honest in the transmission business -- not a common commodity -- have them look at it. It may need service and maintenance as well as just topping off the fluids. ATs do need periodic maintenance, and finding problems early can save a $2000+ repair.
JM
JM
You will always have a slight bit of oil in the intercooler hoses.
If you look closely on the bottom of the intercooler there is a small hole drilled in there to allow the oil to drain on its own.
The 2 big signs of a bad turbo are 1.Car smokes bad at idle. 2. There is no boost at all with all hoses good.
Check out in the General section I made a post with links to sites.You should be able to search those sites and find what you are looking for.
shoeboxOH
2001-2013 model year V70
12
02-09-2015 10:27 AM
