Tranny Solenoids
Old Jul 15, 2005 | 03:57 PM
swede850T's Avatar
Default Tranny Solenoids
Anyone have an idea why the Transmission would click intermittently, and continuously while the key is in the "On" position?
Old Jul 21, 2005 | 03:41 AM
swede850T's Avatar
Default RE: Tranny Solenoids
Well, I've replaced both solenoids, the winter/summer switch, and a previous mechanic said that he checked the PNP Switch, yet it still won't get out of limp home mode. The code I got seemed to be 1-2-1, but was hard to determine since the light was actually blinking very erratically. Mr Tech, should I try to replace the PNP, anyway. Also, would my intermittent no start mode be caused by the PNP, since it seems to help to run through the gears really quickly with the car off, and try from Neutral. I really could use some expertise here, cause I'm a former VW Jetta GLI guy, and this 850's got me at my wits end! Thanks for your help!
Old Jul 21, 2005 | 11:32 PM
Yes I would try a new PNP switch.It will cause it to not start.
Old Jul 22, 2005 | 03:03 PM
swede850T's Avatar
OK -- I'll now order the switch with confidence! I will say that after the solenoids, it does shift better once I get up to the higher gears, but now I gotta get first!
Thanks again for your help!
daver
Jan 20, 2015 05:04 PM
Offroadpr
Dec 20, 2013 10:55 PM
bdraper321
Jan 24, 2013 09:16 PM
And1one
Oct 12, 2011 12:25 PM
swede850T
Aug 3, 2005 05:08 PM
