HELP! Huge POP from engine! Lost all power
Old Jul 12, 2005 | 09:56 PM
rp850's Avatar
Default HELP! Huge POP from engine! Lost all power
Hi,
I really need some help. I'm driving home today and just finished cresting a very steep hill when all of the sudden POP from the engine and the car begins to lose power. I pull over to investigate and everything appears OK but I notice a slightly burnt smell. Check oil...fine. Coolant...fine Nothing leaking. Temp gauge shows 3 o'clock...fine. No transmission arrow flashing. Limped the car home 1/2 mile during which time the check engine light appears. Car does not not go more than 30mph. Turbo needle was moving and temp still fine. I pulled the codes and the only one was 1-2-1 which I believe is the MAF? Could this have malfunctioned like this or is it a symptom of something else?
Thanks!
Old Jul 13, 2005 | 01:46 AM
rp850's Avatar
Default RE: HELP! Huge POP from engine! Lost all power
I FOUND IT!!! There is a HUGE hole in the hose that attaches to the TB. I didn't see it at first because it blew out from underneath and the hole really wasn't visible. I felt around and that's how I found it. I took a photo for you all...
[IMG]local://upfiles/2175/D5FC779BCD7048759D0F9452C5D5E262.gif[/IMG]
Old Jul 21, 2005 | 10:17 PM
Glad you found it.Check the others as well.
Old Jul 22, 2005 | 03:36 PM
rp850's Avatar
Thanks! I did exactly that!
Jtree5757
Feb 17, 2014 02:16 PM
mhphoto
Jul 28, 2012 04:59 PM
Need4Svede
Jul 27, 2009 12:54 PM
Joe 850 Bird
Jul 23, 2007 09:39 AM
