transmission noise
Old Nov 30, 2011 | 12:10 PM
slimflex2's Avatar
Red face transmission noise
hey guys l need your help. when l first turn on my volvo 850 r and before or after it shift to first gear l hear a clunk noise from the driver side.what could be that noise?does that mean tranny is going bad?thanks
Old Nov 30, 2011 | 04:00 PM
jbuck's Avatar
Could be a motor or transmission mount. Top transmission mount on the Turbos go bad all the time the rubber bushing falls apart. Up grade it if you can. Little confused, does the "clunk noise" come before or after you put into gear? The motor will torque slighty as gas is applied with a broken mount. The transmission mount in under the car. See the DIY section up front for the repair.
Old Nov 30, 2011 | 09:56 PM
You can have a bad transmission mount. It is under the car and can be replaced in 10 minutes. The rubber gets softer and causes the car to clunk into gear. Also causes the car to shift hard from 2nd to 3rd.
If you haven't replaced the upper motor mount, tranny mount, and/or the front mount behind the right front tire, you may want to replace them. MAINTENANCE!!!
Motor mount, right side, Volvo S70, replacement instructions
Old Nov 30, 2011 | 10:22 PM
slimflex2's Avatar
yea thats right. l hear it when it is in gear but it shifts perfectly. it does that any time l start the car.u cant hear it till my radio is on low volume.
Old Nov 30, 2011 | 10:23 PM
slimflex2's Avatar
and how do l replace the transmission mount?where do l get the parts and how hard is it to replace.thanks
Old Dec 1, 2011 | 08:30 AM
jbuck's Avatar
Here is the link from IPD and the instructions for changing the mount. FCP Groton also has the part.
ipd HD Polyurethane Transmission Torque Mount
Old Dec 1, 2011 | 09:19 AM
slimflex2's Avatar
thanks man. can you post the link to the fcp groton for mount? let me ask you what would be the consequence if l leave it like that for a while before changing.do l have to change it as soon as possible or it can be on for a while till l get some $$ for it?
Matticus6288
Feb 16, 2015 03:43 PM
chimmychong
Apr 2, 2008 08:39 AM
brainymas
Mar 24, 2008 09:32 PM
ludeless
Aug 28, 2007 07:14 PM
mistuh2
Oct 15, 2005 01:23 AM
