Trip Computer
Old Apr 22, 2005 | 12:14 PM
skifloyd420's Avatar
Default Trip Computer
My battery died the other day and I jump started it. When Iturned the igniion on the trip computer blinked and then just completly turned off. I can't find a fuse for this and was wondering if there actually is a fuse somewhere for it or if there is an easy fix for this with out taking the instrument cluster apart. Any suggestion are greatly appreciated
Old Apr 22, 2005 | 02:47 PM
Default RE: Trip Computer
Do you have the switch on the side for the diffrent functions?
If it does sometimes they have a reset button on the switch.
The only other thing I could suggest is try pushing the minute and hour buttons and see if it comes on.
Old Apr 22, 2005 | 06:59 PM
Already tried pushing minute and hour buttons together and pressed the reset buttun for 5 seconds. Light behind the trip computer still works but it doesn't show any numbers. 1994 850 Sportwagon
Old Apr 22, 2005 | 07:54 PM
Im not sure then.It might be burned out.If you want to tackle getting to it let me know and I will type the instructions for you.
Old Apr 23, 2005 | 05:59 PM
That would be great
Old Apr 24, 2005 | 03:46 PM
Open the left side front door on the end of the dashboard there is a plastic peice.Remove the round cap and the screw then remove the cover.There is another screw under that cover.Then remove the speaker cover and remove the plastic clip.Push the center part of the clip one click then remove the clip.Next remove the A/C vents all the way across the dash.Use a small screw driver and pop the vents out.There is screws under there going up into the dash pad.There is also a couple by the speedo cluster.
If you want you can lift up on the left side of the dash and sneek the speedo cluster out.It can be done.
If you don't want to do it that way the continue across the dash remove the screws.Then remove the glove box insert and there is 4 10mm screw that go through a metal plate into the air bag.Remove them unplug the airbag.Then after removing the speakers and the screws from the right side the entire dash pad.
Unclip the speedometer cluster and unplug speedo and it should lift right out.
If you have anymore quiestions feel free to ask.
Old Nov 6, 2005 | 11:38 AM
joelongwood's Avatar
I had the exact same problem last night. The trip computer display went completely blank after a jump start.
I read in another forum that the fix involves disconnecting the negative battery terminal for a few seconds and then re-connecting.
I tried it this morning, and VOILA!.......everything sprang back to life, although the clock has to be reset.
Hope this helps someone, as I've read a few posts describing similar situations.
airtech_78
May 25, 2008 06:18 AM
Steamroll9
Feb 24, 2008 04:58 PM
Pretorien
Jun 22, 2006 11:29 PM
androide016
Mar 31, 2006 09:14 PM
tchase1
Mar 11, 2006 11:22 PM
