brake question
Old Nov 5, 2005 | 07:03 PM
tomservo's Avatar
Default brake question
So should the rubber piece around the piston stay attached to the caliper or the piston? I was changing pads and got one side done, but couldn't compress the piston on the other side and realized the rubber "ring" was pulled away from the piston and was connected at all to the caliper. Do I need to replace the whole caliper. Note: I'm no mechanic, just trying my best.
Old Nov 6, 2005 | 12:25 AM
Default RE: brake question
The boot is attached to both.One end on the piston and the other to the caliper.
They fall apart with age.Evantually they will get dirt in there and hang the caliper up.
If it moves freely then you will be fine for now.
Old Nov 6, 2005 | 01:30 PM
tomservo's Avatar
The problem is I can't get the piston to compress so I can change the pads. Any ideas on loosing it? I am also trying to decide if I should attempt a rebuild or buy a rebuilt. Thanks.
Counselor828
May 18, 2009 09:58 PM
MaZoN
Aug 5, 2008 06:52 PM
thullz
Nov 7, 2006 09:25 AM
mywifescar
Jan 13, 2006 12:59 PM
