trouble codes
Old 02-06-2006 | 08:37 PM
katrina's Avatar
Default trouble codes
Hi I just got a po730 code on my 94 850 turbo what does it mean .
thanks for any help
Old 02-09-2006 | 01:31 AM
sithhound's Avatar
Default RE: trouble codes
Here is a list of Volvo codes. I do not see a 730, but I am new to this, and do not really know what I am talking about. Are you sure it was 730? If so, maybe someone else has a clue. Anyone?
codes
Old 02-09-2006 | 10:17 AM
JimKW's Avatar
P0730
Incorrect Gear Ratio
This is what I got off of another sight. Have no idea what that means, but that's what the code says.
Here is the sight I got it from:
http://au.geocities.com/ozbrick850/obd2codes.html#obd-2
Old 02-09-2006 | 09:46 PM
katrina's Avatar
Thanks for your help.
It sounds like a gear box problem ,what should I check next.
Cheers.
Old 02-10-2006 | 01:36 AM
m1964's Avatar
How did you get the code -did you put "cold" transmission into 3rd gear?
If yes, it may not be a problem -just clear the code and do not put tranny in 3rd when it's cold. You will not get the code back
Old 02-11-2006 | 04:56 PM
What Im wondering is how you got the P code out of a 1994?
It is impossible unless you have an adaptor for a scanner to read codes under the hood.
Also unless you have a secret 1994 that has an OBDII plug inside the car.
But yes the code is for incorrect gear ratio. Try clearing it and see what happens.
axelm
07-03-2015 08:48 PM
B1mmer
12-18-2006 11:24 PM
mrscullini
11-24-2006 03:28 PM
mrscullini
11-11-2006 05:30 PM
TBoone
08-08-2006 12:52 AM
Quick Reply: trouble codes
