Trouble with shifter
Old Feb 8, 2010 | 11:16 AM
cynthia's Avatar
Default Trouble with shifter
My 1997 Volvo is giving me problems with the shifter...When I turn the car on and go to shift into gear, the shifter will not move. I have to turn the car off and try again, after several attempts it eventually will go into gear. What do I need to do to correct this problem
Old Feb 8, 2010 | 02:56 PM
Did you try putting different pressure on the brake pedal? Did you try wiggleing the key in the ignition? Also try playing with the button on the shifter.
Other than that, there is a shift lock cable that goes from the ignition to the shifter area. That may be out of adjustment or something.
Old Feb 8, 2010 | 03:12 PM
Legendsecko87's Avatar
Shiftlock override for the time being should solve it.
xDread92x
Jul 21, 2019 04:18 PM
jasond011
Sep 13, 2010 04:02 PM
sandraqu
Dec 24, 2009 02:36 PM
panopticon
Mar 21, 2005 09:38 PM
Kordax
Jun 16, 2004 12:17 PM
