true mileage
Old Jun 7, 2006 | 02:19 AM
t.d.'s Avatar
Default true mileage
Noticing while researching 850s that the odomoeter seems to break quite often. Whats the trick to pull the true mileage off the ECU?
Thanks
Old Jun 7, 2006 | 12:45 PM
Psaboic's Avatar
Default RE: true mileage
Try this
http://volvospeed.com/vs_forum/index...howtopic=23540
Glenn
Old Jun 7, 2006 | 01:06 PM
robert213's Avatar
Procedures for ODB-I (model years 1993-1995 and some 1996) r213faq
http://www.matthewsvolvosite.com/cha...pic.php?t=6731
As long as you have the DTC boxes up under the hood ('93-'95).
1. Switch ignition on
2. Connect the fly wire to socket - A7
3. Push button 5 times
4. When LED comes on and stays on, enter code 1-1-1 as follows:
- press the button once when LED is still on
- wait for LED to go out and come on again
- read off response, which will be the last three digits of the odometer miles
5. Repeat steps #3-4, but enter code 1-1-2 (that is, press the button twice on the last step); read off the response, which will be the first three digits of the odometer miles. If you have less than 100,000 miles, the first digit will read as 10 blinks.
I had printed out. Figured it was worth keeping and credit goes to Gerald C who had provided it:
1. Switch ignition on.
2. Plug wire to module A, terminal 7.
3. Push button 5 times.
4. When LED comes on and before it goes out, enter code 1-1-1 as follows:
- press button once while LED is still on
- read off the response, which will be the last three digits of the odometer miles or km
5. Repeat steps 3 to 4 but enter code 1-1-2 (that is, press the button twice on the last step); read off the response, which will be the first three digits of the odometer miles or km. Numbers that are zeros will read as 10 blinks.
Procedures for ODB-II (model years 1996 and 1997)
Must have ODB-II DTC Reader with ability to read ECU's stored parameters in memory.
--Edit--
mileage data is stored in odometer gauge cluster
--Edit--
Old Jun 7, 2006 | 08:50 PM
For the OBDII cars the Scanner will have to be able to Read the Instrument cluster. Thats where the milage is calculated.
Old Jun 7, 2006 | 11:50 PM
t.d.'s Avatar
Awesome info. Thanks alot everyone. So for late 96 and all 97's you MUST have the OBD II scanner to pull the mileage? Was the odometer failure issue primarily in the early model 850's?
Old Jun 7, 2006 | 11:55 PM
It was a problem in all the 850's from 1993 to 1997.
Old Jun 8, 2006 | 10:09 PM
t.d.'s Avatar
hate to sound completely ignorant here, but where is the "fly wire" located in proximity to the DTC? Is it a pretty obvious testing wire?
Old Jun 8, 2006 | 10:11 PM
It comes out of the A box it is a black wire it should be stuck in the A cap.
Untuned
Jan 12, 2010 06:48 PM
placer61
Feb 3, 2009 03:05 PM
painthunter9
Jul 27, 2008 07:27 PM
bretm
Mar 14, 2008 09:38 PM
tim
Feb 23, 2005 09:59 AM
