tried and true mods?
Old Feb 27, 2008 | 09:50 PM
bretm's Avatar
Default tried and true mods?
Anyone have any tweak mods they have done for some mo power on a stock s60???
I have heard besides puttin in a k/n filter to pull out the screen in side the maf for better flow anyone tried this.is there anything i can do to this car without having to buy bolt ons
Old Feb 28, 2008 | 08:20 AM
S60 R's Avatar
Default RE: tried and true mods?
This is prob the best you can do...
http://www.bsruk.co.uk/tuning_ppc.htm
There are other companies that offer this also. Just plugs into the OBD II and in a few minutes it's programmed.
Old Mar 3, 2008 | 03:48 PM
turbos60's Avatar
Get an ECU tune, the most bang for your buck
Old Mar 3, 2008 | 03:50 PM
S70driver's Avatar
Do not remove the screen on the MAF. You heard wrong. It will not increase your power. What it will increase is the chance to truly damage your engine.
So do not do it.
1. What is your budget?
2. What is your Hp goal?
3. Are you N/A or turboed?
Lets start with the basics first. Then move on.
Old Mar 7, 2008 | 06:29 PM
bretm's Avatar
YES TURBO, I HAVE A K/N FILTER TO INSTALL TONIGHT. REALISTIC UNDER 1000.00 AND 15 HP OR ATLEAST SOMETHING I CAN FEEL
Old Mar 7, 2008 | 08:22 PM
bretm's Avatar
WELL INSTALLED FILTER TEST DROVE CAR AND FELT A BIT MORE POWER.MONGO LIKE, MONGO WANT MORE,MONGO NEED GET CREDIT CARD FROM WIFE AND BUY MORE
OH YEAH CAR IS FWD
Old Mar 8, 2008 | 01:18 PM
S60 R's Avatar
ORIGINAL: bretm
Your best bet is the PPC ECU upgrade.
Old Mar 14, 2008 | 09:20 PM
bretm's Avatar
what would be better a new down pipe w cat or a cat back system how hard is it to install and which would be best to do?
Old Mar 14, 2008 | 09:38 PM
S60 R's Avatar
Witha turbo engine,a bigger downpipe should give you more than the cat-back. I would get both to be honest, but if you have to choose one, I would go with the downpipe.
I guess it depends how mechanically inclined you are. A friend of mine is a mechanic, and one of the bolts from the dp to the turbo housing broke off requireing it to be drilled out. Luckilly he had the tools to do it (which I don't) and it was still a PITA, so anything is possible.
HenryRW
Jun 13, 2014 07:20 AM
urdrwho
Mar 9, 2014 01:50 PM
t.d.
Jun 8, 2006 10:11 PM
tim
Feb 23, 2005 09:59 AM
