Trunk strut plastic clip.. replacement part available??
Old May 30, 2008 | 02:36 PM
1974Fiat's Avatar
Default Trunk strut plastic clip.. replacement part available??
Hello. I just purchased a '96 ..850..The trunk strut(hook) clips that thread onto the piston rods have broken. Does anyone know of a source for the clips without having to purchase the entire strut. The struts look new but the clips are toast.[:'(] That is one HEAVY TRUNK LID!!
Thanks in advance to any replies, Cheers, Doug.
Old May 30, 2008 | 06:18 PM
Default RE: Trunk strut plastic clip.. replacement part available??
I don't think they sell them seperate.
Try a Junk yard for some junk ones and get the clips from them.
Old May 31, 2008 | 12:01 AM
JPN's Avatar
JPN
And when you install the rod, make sure to exert force from inside car, not from the trunk side. Remove shoulder paddings from the rear seats so you can get access. Press down directly on the claws. If you try to press down on the rod from the trunk side, either the rod will bend or the claw will break. Also, when you open the heavy lid, do not open it too high, which will also break the claw.
JPN
Old May 31, 2008 | 07:05 AM
1974Fiat's Avatar
Thanks for replies.. I think I will try to make up some metal clips..We'll see how it goes. Doug
Old Jun 3, 2008 | 11:19 AM
Systek's Avatar
ORIGINAL: JPN Also, when you open the heavy lid, do not open it too high, which will also break the claw.
JPN
yeh, this informatin is about one month too late [:-]
Vmax
Mar 14, 2014 07:35 PM
jollygoodgold
Mar 21, 2013 05:32 PM
V70VolvoWagon
Dec 27, 2010 11:45 AM
hiendaudio
Aug 6, 2010 03:11 PM
cdalexc
Jul 1, 2008 11:43 PM
