turbo
Old Aug 7, 2005 | 03:28 AM
DavidSchneider's Avatar
Default turbo
one quick question how much labor would it be to put a t-5 turbo on my 97 850 GLT turbo
Old Aug 7, 2005 | 12:11 PM
Default RE: turbo
Shop labor or time for you to do it?
Shop labor I think is like 3 to 4 hours.
The average person it might take half a day or a little more depending on wether there is problems or not.
Old Aug 9, 2005 | 06:02 PM
Rand850's Avatar
Default RE: turbo
You just can't swap or add a turbo, the T5R turbo's waste gate is electronically controlled where the normal turbo is vacuumed. You have to have the computer from a 97 R to even add it to your car and it the computers have different harnesses you have to change the harness too!
Old Aug 10, 2005 | 09:24 PM
Default RE: turbo
the reason i ask is because a buddy of mine is parting his 1997 T-5 so i can get my hands on his TD04HL-15G turbo but all i was wondering if it is going to take extensive labor or if it will be simple bolt on and go so to speak thanks alot and i would prefer to do the work myself as long as it is not excedingly complex
Old Aug 11, 2005 | 12:45 AM
Default RE: turbo
You should be able to get it on there.If worse comes to worse swap the waste gates.
1Gray760T
Nov 13, 2009 08:19 PM
