Turbo Lag
I have one more for you guys. My 97' 850 R Wagon seems to be lagging a bit when the turbocharger engages. This is my first Volvo, and my first turbo charged car but I thought it would push a little harder towards the higher RPMs. In other words, when the turbo kicks in, it kicks pretty hard but then seems to ease off too soon. Is there any test I can do to make sure I have a properly working turbocharger and or fuel delivery system? Does anyone else have any experiences like this one?
Thanks,
Chet
Thanks,
Chet
Lots of people replace parts with non stock parts, that's how you mod a car. Adding an aftermarket boost gauge is pretty common, since the stock boost gauge is pretty useless. If 15Gs are prone to boost fade, that means that yours is fine. Now if it's horrible boost fade, then may need a new turbo, but you won't know that until you know how much your boosting and what it's dropping off to.
What is a 'CBV'?
Something I have noticed in many threads is the use of acronyms. I think as a general service to all users of the forum, be it new guys or old that we spell out the acronyms for all those reading. I am embarassed to ask the question but I really cant figure it out. 'control boost valve'?
Actually, post *****, it does not allow do anything to the wastegate. All it does is when you let off the gas, the turbo piping has all this metered air that it needs to recirculate, so it goes back right before the turbo. The the intake manifold now has a vacuum since you let off the gas, and this negative pressure has let open the CBV, alowing the pressurized air in the turbo piping to get recircluated.
Well regardless, it says right in the description delayed boost, if he's having boost lag, then this might be fix.
I was just making fun of yourself because you called yourself a post ***** in another thread.
:P
No worries, I don't even know what I thought a CBV was when I was looking it up.
The delayed boost would be because some of the air is seeping though the CBV back in front of the turbo, but after the MAF. This can be caused by a rip, or a weak spring.
Edit:Trying to find the post of the post ***** part...![Smile](https://volvoforums.com/forum/images/smilies/smile.gif)
Double Edit:
FouND IT!
:P
Double Edit:
FouND IT!
Bah hahaha.
I forgot about that. Sorry for the response. I'm little snappy because I'm at work right now and my boss didn't show up, and another person decided not to come in without mentioning it to any of us, and it's the busiest day of the week, and it's been non stop since six this morning and I've been up since five, and there's still a lot to do and it's raining out so there aren't even any hot girls walking around campus right now for me to look at and feel better and it's just been a rough morning and I'm on my 9th cup of coffee.
I think he should hook up a boost gauge to see if he really has an issue at the moment or that the car is acting completely normal and he's just not used to it.
edit: And I am a post *****. So what of it?!?!?!?!
![Big Grin](https://volvoforums.com/forum/images/smilies/biggrin.gif)
Is it just me or are you guys forgetting he has an R?
I thought the ECU is setup in the R and T5-R to only have the max hp (240hp) only for ~20seconds when you floor the pedal, then it drops back down to what 220ish????
And the 15G does drop out in the higher rpms, just not as bad as my little 13C, which is ~5000rpm.
