type of synthetic oil in the northwest (chicago)
I live in the northwest, particularly in the Chicagoland area. I am going to change the car over from regular oil to synthetic. What weight/viscosity oil should I use. I am used to using 10W-30 regular oil in my other cars, but I've been hearing of people using much higher viscosity oils, such as 0W-30. What should I use for my area? I've also found an Amsoil dealer near me, so I might try the stuff, but I also heard that Valvoline synthetic keeps the seals moist, and helps with the cleaning of the engine, and re-vitalizing the seals, so as that you don't get any leaks, or much less. What kind should I be using. The car that I purchased has 140k on it. Thanks in advance.
RE: type of synthetic oil in the northwest (chicago)
One more question Mr. Tech. I am a little bit worried about putting synthetic oil in my car. It has 140k, but the engine does seem to knock a little louder than most of the cars that I've had. Also, I would like to make it last, so I thought that synthetic would be a good choice. However, with all that you have read about my car, and the possible leak in the rear seal, would it be wise to put synthetic in? I may be asking for a lot more leaks. And, i know what i've read about the Valvoline rejuvinating the seals, but i'm still not sure. What do you think? I know that you don't know that much about the car, but with everything that i've written, would you say it's a good choice to use the synthetic, or not?
jollygoodgold
07-16-2007 01:06 PM
