Recycle Air on 94 850
Old Apr 12, 2005 | 03:05 PM
CFGVolvo850's Avatar
Default Recycle Air on 94 850
The Recycle Air Control button on the Climate Control Panel lights up when flipped to the "ON" position, but doesn't seem to work. The outside air keeps blowing in. Any suggestions? Thanks....
Old Apr 12, 2005 | 03:40 PM
JimKW's Avatar
Default RE: Recycle Air on 94 850
Close the vent. **** to the far left of the Dash vents. I think it's up to close it and down to open it. The 98 V70 is the opposite and I kind of forget which one is which. I beliveve the button you are referring to is for A/C only.
Old Apr 12, 2005 | 04:50 PM
Remove the glove box insert by opening the glove box door.Then removing the t-25 screws around the insert.Then using a small screwdriver insert it into the door where the rod goes into the door to release the rod.Once you remove the insert then look inside.There will be a motor with a rod going to it.Or not going to it the plastic dogbone looking peice of plastic breaks.That it what controls the recirc door.It might have just fallen off to.If it does grab it with a pair of needle nose pliers and hold it up there and activate the motor holding pressure.When the motor and the plastic peice match up it will slide on.
Old Apr 18, 2005 | 02:20 PM
TECH, you're a genius! The bone-like piece was broken, where it attaches to the motor. The motor work perfectly. I'm going to get the part from Volvo today. Thanks for the info.
Old Apr 18, 2005 | 02:26 PM
Let me know if you have any trouble getting it in.
Old Apr 27, 2005 | 01:21 PM
Replaced the plastic bone-like piece going from the motor to the rod this past weekend. The recycle air works perfectly. Thanks again TECH.
Old Apr 27, 2005 | 07:09 PM
Your welcome.
Old Apr 27, 2005 | 08:13 PM
panopticon's Avatar
Thanks to you Tech, you are THE MAN.
My son has asthma, and while driving around in the Volvo on Atlanta traffic I would swear I smelled outside fumes, and air would come in thru the middle vents so we always had them closed.. I have an old Saab, and air comes thru the middle vents always, so I thought this was normal for the Volvo so we just put the air flow on 'feet' all the time. Well I read this post, and went out after work to check it out..I'll be damned if the wishbone plastic on ours was broken too! I took it off and will locate a replacement soon. All this time we have been driving around with traffic fumes coming into our car. I took a tie wrap and tied it so that it's shut until I fix it.
Thanks again, I appreciate that you are here!
Lars
Old Apr 28, 2005 | 10:09 AM
Your welcome anytime.
I just do what I can to help.
olesy1064
Oct 25, 2011 08:04 PM
elbert
Oct 18, 2011 10:54 AM
91shelby
May 31, 2010 10:08 AM
austeve
Jul 29, 2008 09:08 PM
outblast
Jan 1, 2008 01:52 PM
