Ugh, not again...Check Eng Light
So I was out driving today, finally got the car back together after the PCV system done and the EGR cleaned out. I was enjoying not seeing the service engine light. Key word is WAS. Light came back on again today and is coming back as a code for the knock sensor. Now, i KNOW I moved it when i was doing the PCV system, because it was in the way of taking off the bracket that holds the intake manifold from the bottom. I dont remember 100% if i got that bolt back tight or not, but I'm guessing that it didnt go bad, it just isnt tight. Can I get at this little booger without removing the intake manifold again?
Oh, does the knock sensor have to be installed in any particular orientation? because i KNOW i didnt put it back to where it was.
