Unburnt fuel smell
Old Jun 30, 2012 | 09:35 AM
radio16's Avatar
Default Unburnt fuel smell
HI all long time since ive been here - update - got my ard green tune pushin 17 1/2 psi @2850 rpm problem is i cant find the where the fuel smell is coming from. havent retarded the timing 3 deg on intake and exhaust yet - dont quite know how, need advice on finding fuel smell -- dont say use a match thanks.
I had an accident in my baby - no body damage- but lost 3 wheels @110 mph from road debris off a ****ing semi, and ended up in hospital 6 days later from internal bleeding, perforated stomach and torn upper intestine- hemoglobin count supposed to be 14 - mine was 4 - needed 6 pints of blood and emergency surgery - heart stopped 2wice coz it was almost empty - but i survived--- any way fuel smell and timing help would be nice - if i do timing will smell stop?
Old Jun 30, 2012 | 11:06 AM
MattyXXL's Avatar
Richard.... How the F are you feeling mang...
Could be a couple things.
When are you smelling the fuel?
After WOT runs?
Starting?
After fill up?
on another note...
Nov 3rd there will be a BIG meet in Ft Myers, you better be there!!
Old Jun 30, 2012 | 12:04 PM
radio16's Avatar
Default unburnt fuel smell
after wot is when i get the smell - need to set timing to -3exhaust and -2 intake accordinhg to kristiane at snabb
im doin ok still sore and weak after loosing so much blood and having emergency surgery
Old Jun 30, 2012 | 12:46 PM
MattyXXL's Avatar
That sucks dood im glad your ok..
The timing might have something to do with it, but hows your A/F, do you have a gauge
Old Jul 1, 2012 | 07:01 AM
radio16's Avatar
yes i can haz a wide band f/a/ gauge, i was thinking timing too, according to ARD i need to retard my exh. timing to -3 deg and my int. to -2 deg, but is there an easy way to do it without having to buy that ipd tool?
Old Jul 1, 2012 | 12:16 PM
MattyXXL's Avatar
yes and no..... Yes because Im getting the tool made, and Ill be selling them for $12..
No because I havent dropped off the tool to copy because the guy is on Vacation till August
Old Sep 11, 2012 | 05:01 PM
radio16's Avatar
late response,,,,,,,, struggling to save my wife from killin herself on bars guys -- sorry ive not been here--- soon --forgive me ya"ll, ill get her sorted and ill be back -- just pray for her -
Old Dec 12, 2012 | 07:26 PM
Binh Tran's Avatar
hi dont know if you still looking for the answer but i read somewhere that due to bad design volvo s70 and 850 has problem with their fuel pump. you can smell the gas smell in the cabin after couple minutes driving. The solution suggested was bringing it to the dealer and they will adjust that for free. I dont have that problem but i am curious to see how yours goes. (Just like the early 1995s 850 has a recall problem about their car jack not sufficient enough to handle the weight of the car and the result is bring back to the dealer so they can replace that to a better model) hope this helps
Attached Thumbnails Unburnt fuel smell-76724_306041636182471_2096009262_n.jpg
Old Dec 15, 2012 | 02:51 PM
Where are you at with the tool
Old Dec 15, 2012 | 03:04 PM
I'd call the people who did your tune and ask them about the raw fuel smell after WOT. It might just be a normal condition from letting off the throttle rapidly. I doubt that but you never know. That's kind of a stretch since having enough raw fuel you can smell it going through the cat would overheat it and possibly melt the catalyst and plug the exhaust. Well unless your tune included a cat delete and you are not running one. Then it could be a normal condition it's just odd you'd smell it inside the vehicle if it was moving.
Do you have any modifications you didn't tell the turner about ?? Bigger injectors or higher pressure fuel pressure regulator.
I'd still cover the basics and do a good visual inspection of the line from the injectors all the way back to the tank too.
I had a recurring intermittent smell after doing my regulator. Turned out I had a line fitting just weeping enough that once in a while the heat/AC fan would pull gas fumes into the cabin.
The other thing I'd check is around the tank. Maybe you have a leak someplace and it's the jostling of the fuel when you let off and start to brake that sloshes the fuel around enough to get some to leak out. Just taking a shot in the dark.
drothelast
Mar 18, 2015 02:06 PM
blamj
Oct 29, 2009 02:28 PM
RedTurbo850
Jul 12, 2007 01:09 AM
huzzsaba
Mar 26, 2007 10:28 PM
maron96
Feb 13, 2006 09:05 PM
