Urgent help needed, intake hose diagram
I tackled a pcv job today, also added a mbc and ipd manifold spacer. Upon start up the car shot the rpms to the max so I think I have a vacuum line hooked up wrong somewhere. I have two hoses on the intake manifold that I have no idea where they go. I know pcv takes up two lines at the very bottom and one of the lines taps from boost controller but I have two nipples open on the intake . Does anyone have a diagram or knows where all the hoses get hooked up?
Thank you
Thank you
DB, my 850T is home this week, let me know if you need a picture or a specific line to trace (ie from the vacuum tree etc). I can tell you the vacuum tree on my car has two stems stubbed off with caps (one fell off a few months ago and threw a CEL...). also if you can post a pic of where you have the open ends, I can compare on my car.
DB,
To add to the diagram Boxpin posted - the actuator (#16) can be found looking down from the MAF. The yellow (yes mine actually has a yellow mark on it) goes to the waste gate, the blue goes up to the intake tube by the MAF and the green goes to the turbo.
There's also a second actuator (not on this diagram) under the cover for the throttle cable rewind which has a short L tube to the intake manifold and a long tube that goes under the distributor and rides the same path as the yellow and green down to the turbo area. I didn't get under the car or use a mirror - so I'm curious if that's the red tube (#20). These are all the larger (or medium) vacuum tube size...
DB,
In the photo you posted, the open hole (no hose attached) is where vapors from the PCV go to. There's no vacuum there, so it's not really sucking on the PCV, but that is where it vents to. The electric thing on there is just a heater. On a lot of turbos, the vapor off the PCV snakes around on top of the engine, under the spark plug cover, and comes back out. That is also just a heater, and it's confusing if you think that tubing is supposed to go somewhere. It just goes under the spark plug cover and comes out again.
robingichuhi
02-22-2017 04:34 PM
