Urgent Help Needed With Tie Rod
Old Dec 28, 2008 | 11:19 PM
sgtatarms003's Avatar
Default Urgent Help Needed With Tie Rod
on the picture in the link. on the left side is the end or the rod that connects to the power steering. its a female end and i need to know how to unscrew it to replace it before my car rattles apart. i have a 1989 volvo 240 gl any special tool or trick to takeing it off. i saw a small hole on it so i dont know my thought is to slap some vise grips on it and give it hell any help would be very nice
http://www.autozone.com/R,1556074/ve...ductDetail.htm
Thanks
Philip Venero
Old Dec 29, 2008 | 01:26 AM
bubba240's Avatar
Default RE: Urgent Help Needed With Tie Rod
Philip!
You want some rest asuraest? you are doing the right thing until something breaks! stop relaying on what you read, take courage, do what is right and you'll be fine!!!
Old Dec 30, 2008 | 05:55 PM
Beardog's Avatar
there should be a couple of flat spots on the inner tie rod. use a combo wrench to hold it and then use an adjustable crecent wrench to grab onto the outer tie rod and twist. if its stuck, lubricate it with a penetrating oil. don't forget to mark how far it goes on before you remove the original part. when you reinstall, you can get the alignment close.
jands
Aug 28, 2015 11:21 AM
pcgold
Jul 16, 2009 08:12 PM
Kaspir
Apr 3, 2008 12:22 PM
vwdodge
Mar 2, 2005 06:45 PM
sportsdruid
Nov 13, 2004 12:08 AM
