Vacuum line size Turbo to turbo control valve
Replacing my spent vacuum lines while doing maintenance. This hose is larger than the 4.2 mm hose that I bought. Does any know the size? The markings have faded or rub off when I try to clean the dirt off. Think it says 5.2.
Does any know if we can use American standard size instead of Metric?
Where is a good place to get them besides the Stealer?
Yes, I bought 10 feet. Lets me reworks stuff later if needed. Its pretty cheap.
Silicone Boost/Vacuum Hose
dredging up an old thread... what do you use for clamping these on a turbo application? the OEM style vacuum clamps?
I don't know how picky they are where you are but I replaced some of my lines with silicone lines and I failed the visual smog inspection because California insists that you use the regular rubber lines.
am12eaz
May 12, 2022 09:07 AM
rspi
Oct 12, 2011 06:49 PM
