volvo 850 coilovers
Old Jan 21, 2011 | 09:57 AM
bgtuner's Avatar
Default volvo 850 coilovers
i have a 850 t5 wagon and i want to buy coilovers for it however the only ones that i can find are KWs and they dont go that low (2.4 in drop), i jst want to know what other coilovers there are out there because i cannot find any!! also i saw online that audi rs4 coilovers fit on 850 with some modifications jst wondering if anyone knows about that. thanks!!
Old Jan 21, 2011 | 10:22 AM
boxpin's Avatar
PM Gilber33...he has a set.
Old Jan 21, 2011 | 10:33 AM
bgtuner's Avatar
ok thanks will do
Old Jan 21, 2011 | 11:33 AM
gilber33's Avatar
Still have about an inch and a half of drop
There isn't a true rear coilover for 850s. The rear coilovers are simply a thread sleeve like the ones in the picture with a threaded perch that the spring sits on. I ordered a set of the rear IPD sport springs that has a really nice drop, but also has about 5 dead coils that you can cut without risking the spring not seating properly.
KONI DIY COILOVER HOW TO
My coilovers came off of this car which also has the rear IPD springs with a couple coils cut off. He is also running 18s so the stance is a little different. I think where the car is sitting at in these pictures is a bit lower from where mine currently sits. But once I install the rear IPD springs, let them settle, and then cut a couple coils, I will lower the coilovers as much as I can.
Old Feb 9, 2011 | 04:26 PM
bgtuner's Avatar
do u think i will be able to make a set of coils in the front using bilsteins struts instead of koni's?? im asking because i already have a set on the car
Old Feb 9, 2011 | 05:50 PM
gilber33's Avatar
Not as easily. The Bilsteins bulge out at the top of the strut housing. You can use them, but you'll have to grind down the strut for the sleeve to fit over. Which is why Konis are used, they're already a very slim strut and the sleeve fits over them perfectly. I've also heard that Bilsteins can not handle the drop like Konis can and you may blow them out faster.
Where I'm sitting now have a couple spins down:
Danny Zuko
Jul 18, 2012 03:45 AM
hicky
Dec 19, 2011 04:39 PM
cbevis
Sep 23, 2008 07:38 PM
SER
Mar 21, 2008 09:58 AM
S70driver
Jan 5, 2006 07:44 PM
