Volvo 850 Lots of thing breaking!
Old Jun 14, 2010 | 02:14 PM
pdogi's Avatar
Default Volvo 850 Lots of thing breaking!
I own a 1993 Volvo 850 with about 114,00 miles on it. Always been taken care of. It seems lately that the minute I fix a problem another one pops up. Here is the latest I need help with. And by the way all of you have been great with your help. About 25 % of the time I start my car I get a low oil indicator light- not low oil pressure but low oil level. The problem is when I check the oil- it is not low. I need to know where the sensor or sending unit is so I can check the electrical connection and/or change the unit itself! Thanks
Old Jun 14, 2010 | 04:16 PM
vjaneczko's Avatar
Sounds like it might be the Oil Level Sender. It's in the oil pan and will run you about 50 bucks at a dealer. You can read about a repair job here:
http://www.matthewsvolvosite.com/for...ic.php?p=20460
By the way, when you check the oil level; you are checking the oil level when the engine is cold, right?
Old Jun 14, 2010 | 06:40 PM
pdogi's Avatar
Yes I check the oil when the car is cold. Is the plug for this sensor accessible without taking the pan off. I'm hoping its just a corroded connection and maybe it can be cleaned externally. this light only comes on intermittently.
Old Jun 14, 2010 | 06:47 PM
vjaneczko's Avatar
Sorry, it's all inside the pan.
Old Jun 14, 2010 | 07:07 PM
fcpgroton's Avatar
Former Sponsor
It sounds it would be more work then it is worth to fix. I would just check the oil level whenever you get gas. Pulling the oil pan is not the easiest thing to do it the world.
Old Jun 14, 2010 | 10:33 PM
These car have a low oil warning light? I did not know that. How low does the oil need to be?
Old Jun 14, 2010 | 11:59 PM
gdog's Avatar
WTF are you guys talking about???
My '95 850 has low fluid indicators for:
  1. Brake fluid
  2. Engine coolant
  3. wiper washer fluid
but NOT for engine oil.
Are you sure this isn't your Low Oil Pressure indicator coming on at idle?
Old Jun 15, 2010 | 06:28 AM
silkhope's Avatar
yep, my 94 850 turbo has one, but the pan might be a replacement, as it has no wire going to it. Just undo the 2 10mm bolts and pull straight out.
Old Jun 15, 2010 | 07:31 AM
pdogi's Avatar
Default low oil warning light!
Its a red warning light on the far left side of the panel- I don't know how low the oil has to be because i never let my oil get low. Never the less the light comes on intermittently. Just a note- it never comes on for me when I am driving. If it does come on it is when the car is first started and stays on!
Old Jun 15, 2010 | 08:16 AM
boxpin's Avatar
I had a 93 N/A years back and the pan did have a Oil Level Sensor. It was on the front of the pan towards the radiator. It can be replaced without removing the pan. bolts from the outside. I saved it when I replaced the pan.
PM me if you want it.
Old Jun 15, 2010 | 05:50 PM
My car does not have a low oil warning light.
https://www.customers.volvocars.com/...1_1.html#pg1.2
That would be nice.
Blifffster
Aug 4, 2012 03:55 AM
norm740
Feb 28, 2011 04:51 AM
reisskhan
Jun 21, 2010 07:36 PM
dwbf1
Apr 13, 2010 05:50 PM
zilinski6605
May 12, 2006 10:00 PM
