Volvo 850 A pillar door to body plug pinout needed
Old May 23, 2010 | 05:36 PM
PAVolvo850's Avatar
Default Volvo 850 A pillar door to body plug pinout needed
Hi ,
First post... I just picked up a Volvo 850 4 door sedan that was sideswiped against a telephone pole. The fender and front door got the most damage, and the rear door got a bit less. The problem I have is the front door to body harness/plug was ripped out and I need the pin out locations on the round plug to get it back together. I think I can fit it back without too much trouble, but I can't find a picture of this plug anywhere. I made a sketch of the plug and there is 14 pins on the outer circle and 10 on the inner circle, and a central square locating notch in the top of the plug in the 12 o'clock position. Some of the cavities are not used. Anyone have a picture of this or a diagram? Thanks in advance! Cheers, Mike
Old May 23, 2010 | 08:01 PM
Sorry I do not have one on hand I will try to dig one up.
What exactly do you need wire colors to where?
Old May 24, 2010 | 10:15 AM
PAVolvo850's Avatar
I found the diagram I needed.... It was called "Connector 24/6" it is the harness that goes between the door and the A pillar... The one thru the black rubber sleeve that connects to the pillar with the twist lock ring. Thanks for the reply though. Cheers, Mike
Aiper Frenc
Jul 30, 2013 03:48 AM
kendogg
Oct 20, 2010 10:54 AM
dcm0123
Dec 28, 2009 04:53 PM
SJ940
Feb 17, 2008 11:40 AM
GoldenAngel
Oct 7, 2007 10:43 PM
