2000 S80 ECU pinout
Old Dec 28, 2009 | 04:53 PM
dcm0123's Avatar
Default 2000 S80 ECU pinout
Hi
Have 2000 S80 with 2.8L T6. 133K
Having problem with VVT solenoid setting P0013 and P1332 codes.
Cleaned VVT solenoid and directly soldered wires to solenoid (cut off connector just in case the connector was the problem) .
Still setting codes.
Does anyone have a pinout of the ECU for this vehicle? It is not in VADIS. I would like to check continuity of the VVT solenoid wire to the ECU socket before I replace the VVT solenoid. I know the contact number the wire goes to on the ECU from VADIS but I am not sure how the ECU contacts are numbered.
Thank you Dennis
Aiper Frenc
Jul 30, 2013 03:48 AM
kendogg
Oct 20, 2010 10:54 AM
PAVolvo850
May 24, 2010 10:15 AM
bigern45
Aug 5, 2008 08:14 AM
SJ940
Feb 17, 2008 11:40 AM
