volvo 850 se wont start with ignition key
my volvo 850se 2ltr 5cyl 20valve 1994 refuses to start with the ignition key. tow it and it starts and runs fine..... the onboard computer shows no fauits and this is completely baffing me......when the key is turnedthe engine turns over. but there is no spark......on releasing the key, the coil gives a spark.....we have changed the coil,and the but it is still the starter but it is still the same ....it seems as though when the key is turned fully it drains power from the coil but sparks when the key returns to normal running position.......any help on this would be apreciated. thanks ......col 850
i have check all the ground wires ....i have check all the ignition wires... i have check all the wires at the starter ... i have check all the wires at the coil and the onboard computer shows no faults .... and this is completely baffing me...it seems as though when the key is turned fully it drains power from the coil ...but sparks when the key returns to normal running position....any help on this would be apreciated thanks....col 850
tech help me... i have been at the car all day got a new ignition switch and a new coil if i take the small wire off the starter i have over 12 volts ...at the ignition switch i have over 12 volts at the small wire at the starter when you turn the key and the starter is working it is over 9 volts at the small wire ....clean all the earths when the key is turned the engine turns over....but there is no spark ...... on releasing the key , the coil gives a spark....help
#17
volvoloco
06-27-2011 07:44 PM
