Volvo 850 turbo
Old Oct 24, 2008 | 06:55 PM
mackmxz's Avatar
Default Volvo 850 turbo
Hey guys- new to the forum and used the search feature first but didnt find an exact anwser. What is the tool that is needed to get the lines off the radiator? It looks like it takes a special clamp in order to get them off. Also any other info you think i would need to know before starting to replace. Thanks.
Old Oct 24, 2008 | 07:06 PM
Default RE: Volvo 850 turbo
Are you talking about the tranny lines and/or oil cooler lines?
If so I use a pair of snap ring pliers that open backwords. When you squeeze the handles the pliers open.
Also be careful the clips break.
Old Oct 24, 2008 | 07:38 PM
mackmxz's Avatar
ORIGINAL: tech
It doesnt appear that snap ring pliers would remove them, unless it is just those metal clips that hold them on? wish I had a picture, it the four smaller lines that connect to the radiator.
Old Oct 24, 2008 | 07:39 PM
mackmxz's Avatar
ORIGINAL: tech
Old Oct 24, 2008 | 08:09 PM
Yes the snap ring pliers will fit into the little indents in the split section and open the clip some then slide it over the line or hold it open and slide the line off.
Old Oct 24, 2008 | 08:13 PM
The 2 metal clips in the middle of the picture are the ones holding the lines on.
http://www.fcpgroton.com/product-exe...ategory_id/214
Keith Tobberman
Sep 30, 2011 10:36 AM
denver005
Mar 12, 2011 09:59 PM
1Gray760T
Nov 13, 2009 08:19 PM
carmanj
Dec 7, 2008 12:31 AM
Keith Tobberman
Oct 23, 2007 08:33 AM
