wagon tailgate suddenly loose, won't latch tightly
Old Jul 9, 2010 | 02:16 AM
850forum's Avatar
Default wagon tailgate suddenly loose, won't latch tightly
I broke something somehow... I had the gate propped up with a stick since the struts failed long ago. I was going to transport a thin piece of 4x8 paneling sticking out the back, and realized it was not strong enough to tie the tailgate down against it -- the panel would have been damaged while driving with the gate resting & bouncing upon it.
I tried shoving my stick between the roof and the open tailgate, but after 60 seconds I decided that the weight of the tailgate bouncing would damage something while driving, and that I had no way of tying the gate firmly in a fully open position.
I removed the 4x8 sheet and tried to close the gate. I _think_ that the locks were locked, and the tailgate would not latch. Is that the normal behavior? I would have thought that the latch would close even if the key had been used to lock the car while the tailgate was open.
After unlocking the doors, I discovered that now the tailgate will not close tightly. It is very loose (not merely a rattle).
What did I break & how do I fix it? Maybe I pushed the latch (aka Lock Brace) out of proper position, or even broke something? It looked OK but that was before I Searched and found info on how it breaks.
I found this on how to fix a broken latch (aka Lock Brace)
http://volvospeed.com/vs_forum/index...te-rattle-fix/
And another way to adjust the door tighter if it were just a rattle:
http://www.matthewsvolvosite.com/for...rattle#p117843
Or perhaps holding the tailgate up by putting my stick on the roof caused the hinge connection to "stretch?" It appears that the hinge is a curved rod that seems to be attached to the tailgate with some Torx screws -- so maybe it got yanked "longer" and now the angle of the tailgate in the closed position is incorrect?
I need to find some photos & info on how the tailgate hinge works, but Searching yielded no information.
Old Jul 9, 2010 | 12:11 PM
vjaneczko's Avatar
Close your hatch and check it for fitment on all four sides. If it's not set properly, you can make adjustments at the hinge along the top - but you'll need another pair of hands - maybe two pair - because of its weight.
If the hatch is aligned properly, then odds are good that it would be the lock brace that needs adjustment - or replacement. It might be possible that the locking mechanism in the hatch itself has become loose, so check that.
And get a couple of replacement struts from FCP. They're cheap and the repair is very easy. It took me a few years to get around to it, but I kicked myself after doing it 'cause it was such a relief not having to monkey with it anymore!
Old Jul 9, 2010 | 02:53 PM
850forum's Avatar
But what caused it to happen?
If the doors are key-locked with the tailgate open, should the tailgate close?
Old Oct 10, 2010 | 11:27 PM
darrinf15e's Avatar
How do you adjust hatch fitment? I have a small gap on the passenger side at the top of the hatch and the right side is flush. the hatch seems to close fine and has normal rattles from plastic.
P_Sanders
Oct 15, 2012 02:33 PM
4volvos
May 17, 2012 04:15 PM
Xyzzy
Jul 8, 2008 09:36 AM
Shaun Oriold1
Mar 16, 2008 06:54 AM
Juneappal
Jul 11, 2007 11:10 AM
