want front big brakes
Old Apr 17, 2012 | 07:45 PM
jasenklems's Avatar
Default want front big brakes
I am thinking of getting bigger brakes for the front want to try to stay with oem parts so I was thinking of changing the front knuckles with those from a v70r the stocks for this are 13 inch and the bracket is cast in the knuckle and the brembo 4 piston callipers just really want to know if the knuckles will fit or if they wont... has anyone tried this before or what
Old Apr 18, 2012 | 07:46 AM
gilber33's Avatar
Um, I hiiiiighly doubt you can just swap on the hub from an S/VR. Because if you could, guarantee it would have been done on Volvospeed a long time ago. Besides that, the front calipers from the S/VRs do not fit 850s/X70s. There are some people in Sweden that have done it, but takes quite a bit of custom fabrication.
Easiest thing would be to buy the caliper brackets and rotors for the 302mm brake kit the 2000 V70Rs came with. Uses the same caliper, but you go from a 280mm rotor to a 302mm rotor. Otherwise beyond that, you're talking serious money for a 330mm BBK.
Old Apr 21, 2012 | 09:03 PM
The 302's are a good improvement. Remember to get the hoses too. Because the caliper is mounted out a bit more the hoses for the 302 setup are a bit longer.
Old Apr 22, 2012 | 03:43 PM
gilber33's Avatar
You don't need to. Running SS brake lines for a 280 rotor with zero problems.
Old Apr 22, 2012 | 06:31 PM
Mad Matt's Avatar
Doing an all OEM front BBK would be pretty cool but not really feasible like
gilber33 mentioned.
Personally I'd just go with the Porsche BBK and call it a day. If you want an OEM look, paint the calipers silver and add the R decal.
Old Apr 22, 2012 | 10:56 PM
It's just a good idea to use the longer lines if you're staying with stock rubber hoses. The SS lines are longer as the application covers our 850's and also the 70's with the bigger rotors.
I don't know that you'd have a problem with the stock hoses that come with an 850 with stock 280's on the bigger rotors but if you were all the way over against the stop and hit a pot hole that little extra length might make the difference between driving on or getting towed.
That and the hoses on there now are likely the originals and cracking so you'd be replacing them anyway and you might as well get the longer ones.
I'm still running the original 280 hoses (they're cracked), I'm planning on going stainless soon.
Old May 2, 2012 | 12:02 AM
850R_black_edition's Avatar
is there a thread for a instal on those 302 rotor upgrades? i'd love to check that out!
Old May 2, 2012 | 10:28 AM
gilber33's Avatar
It's no different than any other brake job. Get 302 caliper brackets and 302 rotors. Install. Done.
Old May 2, 2012 | 11:16 AM
nice...
thx!
mrvolvos60
Sep 11, 2014 07:39 PM
HoopyFrood
Apr 19, 2014 07:11 AM
ross_theboss
2001-2013 model year V70
May 24, 2013 11:30 AM
s40volvo
Jun 29, 2011 12:20 PM
dmoney
Aug 1, 2005 08:11 PM
