Water Pump questions
Old Feb 24, 2010 | 10:03 PM
91shelby's Avatar
Default Water Pump questions
I took the timing belt cover of my 850 today and found that it had some oil behind the cover towards the lower firewall side of the cover, as well as are there supposed to be teeth missing from the water pump pulley?
Old Feb 24, 2010 | 10:10 PM
Yes teeth missing. I would clean the oil good then drive it and see if it comes back.
Old Feb 24, 2010 | 10:11 PM
matt01's Avatar
NO!
if oil has leaked onto the belt it has weakened it. it my be your cam seals or crank seal.
You must change timing belt/water pump and cam seals, and crank seal if it leaks.
Old Feb 25, 2010 | 05:49 PM
91shelby's Avatar
The timing belt is made if rubber which is made from which is petrolium based right? So the teeth missing is normal? I m pretty sure it's not my seals the PVC system was pretty plugged up and the oil is only on the firewall side it looks the oil return o ring for the turbo has been leaking though
Old Feb 25, 2010 | 06:48 PM
boxpin's Avatar
I think he means teeth missing from the waterpump pulley. Yes, if you look at different water pumps, some have missing teeth.
Old Feb 26, 2010 | 12:31 AM
gdog's Avatar
Really? I never seen that; does someone have a picture? Wonder why they would do that?
majorcode
Nov 4, 2013 06:41 PM
scrap88
Apr 7, 2010 09:23 PM
bkraff18
Jun 24, 2008 08:45 AM
katiejoyful
Dec 12, 2007 04:49 PM
flapper
Oct 22, 2007 05:56 PM
