What gives the 1995 T-5 the 18 more HP over the regular Turbo?
Old Jun 24, 2013 | 07:39 AM
Mumblix_Grumph's Avatar
Default What gives the 1995 T-5 the 18 more HP over the regular Turbo?
Different turbocharger? Different exhaust? ECU?
Old Jun 24, 2013 | 08:15 AM
Huh? I think you mean the R over the T5. The answer is ECU, it's set to boost higher. Also, it's for the '95 - '97.
1995 Press Release
Old Jun 24, 2013 | 08:05 PM
Is the 95 Turbo basically the same thing as a T-5?
So if I were to acquire an ECU from an R, and plug it in, I'd get the extra horses?
Old Jun 24, 2013 | 08:52 PM
Yes. They sell the R ECU's on eBay and sometimes in the forum.
You can also get a ECU tune to do better than the R's for less than $400 I think. Most do an ARD I believe.
Someone chime in here.
Old Jun 24, 2013 | 11:22 PM
goldponcho's Avatar
I've got an ARD Green tune on my '96 R wagon. Good for 17psi, plus some other features that Lucky and I discussed. I still have the original ECU for my car, but no longer need it. PM me if you're interested. On the other hand, if additional engine mods are in your future, I think you'll be very pleased with Lucky's work. He's a very knowledgeable guy, and doesn't hesitate to answer questions and work with customers.
Old Jun 25, 2013 | 07:58 AM
boxpin's Avatar
Turbo is 9.6psi - 220hp
R is 10.5psi - 240hp
95- T-5R use a Motronics M4.3
96+ 850R use a Motronics M4.4
They are not interchangable due to the A/C but they can be modified to work.
If you have a 95 you have a M4.3 with a designation of 072. You should be searching for the same year or go for an actual tune (which you would be much happier with)
Old Jun 26, 2013 | 01:52 AM
ibified's Avatar
ARD tune will put a pretty big smile on your face, that's for sure.
Old Jun 26, 2013 | 02:49 AM
Vmax's Avatar
Ibified you have the green tune with an 18t. What psi and what exhaust flange?
Auto tranny?
Old Jun 26, 2013 | 11:45 AM
Originally Posted by boxpin
due to the A/C
I thought it was due to the EGR? What is different about the AC?
Old Jun 26, 2013 | 01:59 PM
boxpin's Avatar
EGR is a difference but not a show stopper. The A/C is actual pins/wiring that has to be swapped.
SlickNerd
Jul 24, 2011 07:57 PM
Rich Ard
Nov 18, 2010 01:36 AM
PANTYEATR
May 8, 2009 11:54 AM
Kervin
Jan 27, 2009 03:38 PM
nawlinds
Sep 25, 2008 10:23 AM
