What size Punch for Rear Brake Pad Replacement Volvo 850?
Old Jan 30, 2008 | 02:01 PM
Jomo1994z71's Avatar
Default What size Punch for Rear Brake Pad Replacement Volvo 850?
Simple question,
The punch you guys use to change out the brake pads on the 850, is this just a regular punch you buy at an auto parts store? Small size? I just want to make sure I have everything before I start the job...
Thanks for your time...
Here is a link that has the punch on it...
http://www.matthewsvolvosite.com/shims.php
Old Jan 30, 2008 | 02:22 PM
info2x's Avatar
Default RE: What size Punch for Rear Brake Pad Replacement Volvo 850?
I used a small phillips head screw driver to punch them out.
[align=left] [/align]
Old Jan 30, 2008 | 02:26 PM
I haven't looked at it too closely, but that's a great idea,
Old Jan 30, 2008 | 06:37 PM
JPN's Avatar
JPN
I use one of the smallest punches I have but you can use anything that fits, since not much force should be required to punch the pins out.
JPN
Old Jan 31, 2008 | 08:29 AM
Psaboic's Avatar
I have used a small phillips screwdriver also, and once I even used an old 10 penny nail (yes I can be lazy at times)
Old Jan 31, 2008 | 09:38 AM
JimKW's Avatar
I just use a punch that I use to countersink nails in wood. I have used a nail also. It doesn't take much at all to get them out.
Old Jan 31, 2008 | 09:58 AM
Systek's Avatar
I used a blunt ice pick that was laying around in the shop. going to a store and buying a hole punch is a bit much. YOu can probably find something comparable to what everyone has posted at a pawn shop for about $1...
Old Jan 31, 2008 | 04:08 PM
Thanks for yalls input, I'll try to improvise...
Old Jan 31, 2008 | 08:29 PM
JPN's Avatar
JPN
If all else fails, see attached pic. This should drive the pins out no problem. Observe local regulations & contact EPA for approval before usage.
.......[8D]
JPN
[IMG]local://upfiles/6892/5FEECF14CA964637832D2859D74F12F6.jpg[/IMG]
Old Jan 31, 2008 | 08:47 PM
JPN's Avatar
JPN
An alternative.
JPN
[IMG]local://upfiles/6892/C5E54D9CB96F49DA8F8CF06B4D4A9631.jpg[/IMG]
Old Feb 1, 2008 | 08:43 AM
Psaboic's Avatar
I think JPN is losing it <grin>
Old Feb 1, 2008 | 09:37 AM
JPN's Avatar
JPN
I certainly am, because I'm still stuck in J@p@n.... Someone get me outta here and get me back to the good old States!!!
JPN
Old Feb 1, 2008 | 12:57 PM
wheelsup's Avatar
Maybe if DAL buys NWA you can come home .
rspi
Dec 15, 2010 10:33 PM
V70
Jun 28, 2010 09:39 AM
Tonyleb
Apr 18, 2009 12:49 PM
ricpot
Dec 21, 2008 05:40 PM
Sidney03
May 28, 2006 08:06 PM
