Where's the best place to order OEM front control arms/ball joints? Also bad ABS
Old Aug 23, 2010 | 07:47 PM
STREETFIGHTER50's Avatar
Default Where's the best place to order OEM front control arms/ball joints? Also bad ABS
Looking for my 1996 850 T5 wagon. Also my ABS module is bad. Aren't those really expensive??
Old Aug 23, 2010 | 08:08 PM
Wow FCP vs. OEM big price difference! But is there really any difference aside from the price??
http://www.fcpgroton.com/product-exe...ategory_id/183
Old Aug 23, 2010 | 08:37 PM
Well with the lifetime warranty why not get the cheaper one. IMO of they are scan tech ones I would run away as fast as you can.
If you are handy why not fix your ABS module your self?
Old Aug 24, 2010 | 01:52 AM
I just emailed FCPGroton to see if they're made by/same as the Scantech brand. What happenned? Did u have bad experience with the Scantechs?
Old Aug 24, 2010 | 10:35 AM
I checked IPD also. IPD says theirs are purchased from APA (URO). Not Scantech. FCPGRoton emailed says theirs are from URO (Sweden made).
Old Aug 24, 2010 | 10:46 AM
regime's Avatar
I have head of the cheapies failing in a year... watch out...
Also that lifetime warrenty is only if a machanic puts it in for you. No shadetree'ers
You still get what you pay for I'm pretty sure...
Old Aug 24, 2010 | 12:50 PM
Bobec's Avatar
I have URO's on my Platinum, about 5 months.
(1)Very bad bolts, aka made in china, were supplied from FCP. Ball joint bolt stripped like cutting butter. Told FCP, they offered to send new bolts, I put the originals back in(i needed the car). FCP said they'd use different bolts.
(2) lock rub plate rivet fell out, had to tap and screw.
(3) I was under the car the other day and rubber boots are cracking
Does anyone know where I can get good replacement rubber boots?
I have scantechs on my NA and no problems but haven't used it much.
Old Aug 24, 2010 | 03:49 PM
bw77's Avatar
Website says if you put the part on yourself, and you are not ase, you can pay 10% of part price to get the lifetime warranty.
http://warranty.fcpgroton.com/
Old Aug 24, 2010 | 05:25 PM
regime's Avatar
hurm.... didn't read that part...
Not a bad deal i guess.
But rather then replace the part every year~ish, i'd rather replace it with something decent for a higher price... Time = Money. especially mine.
Old Aug 24, 2010 | 08:31 PM
Yeah I'd rather spend more money on a quality part. Agreed - Time = Money!! That's for sure! Heard these ones made by Meyle Heavy Duty got some good reviews.
http://cgi.ebay.com/ebaymotors/NEW-V...#ht_6836wt_948
Old Aug 24, 2010 | 08:58 PM
I have had to warranty a ton of scan tech ones. Also had to replace a set of scan techs on my own car.
Old Aug 25, 2010 | 05:59 AM
Bobec's Avatar
What did you replace yours with? Just out of curiosity what goes bad on the scan techs?
Old Aug 28, 2010 | 08:21 PM
The ball joints go bad the most. But on my car the bushings went bad on one of them.
stop_at_willoughby
Mar 7, 2014 05:22 AM
jmallie
Sep 1, 2009 05:50 AM
petes99xc
May 5, 2007 02:53 PM
mikwik
Sep 8, 2006 12:07 AM
jaitken
Nov 22, 2005 03:19 PM
