Whining when turning left
Old Feb 28, 2008 | 01:55 PM
Tarquin's Avatar
Default Whining when turning left
My 850R (96) has for the last 6 months developed a whine when turning left.
It only happens when turning left and the volume is dependant on where the heater fan gauge is set. If the heater fan is off there's very little sound, when it's high it's louder.
My local specialist can't find any problems.
Has anyone out there got an idea what the problem might be?
Old Feb 28, 2008 | 06:44 PM
Default RE: Whining when turning left
That is very weird I think it might be a bad blower motor. The bearing might be bad and when you turn the corner the cage might be rubbing the case.
Old Feb 28, 2008 | 07:47 PM
mhphoto's Avatar
My car does the same thing with right turns! I never gave it much thought. It doesn't do it consistently, but on really cold days when the heater's blasting it will definitely make an appearance.
Old Feb 29, 2008 | 08:28 AM
Psaboic's Avatar
A suggegstion is to pull the fuse (or disconnect) the heater motor, then go for a drive and see what happens.
rspi
Sep 12, 2012 08:22 PM
speedracer67
Jul 24, 2010 12:12 PM
juicejuice78
Jun 4, 2009 12:37 AM
jfikentscher
May 7, 2008 09:49 PM
amcdonal
Apr 20, 2007 01:07 PM
