will this fit?
Old Aug 11, 2010 | 11:12 PM
tater's Avatar
Default will this fit?
will an intake manifold from a n/a 2000 s70 fit on my 96 turbo 850? will i see any gains in power?
Old Aug 12, 2010 | 10:42 AM
regime's Avatar
To answer your question directly I'd have to be honest and say i have no idea,
Im not sure of any difference in the intake manifold for turbo, or non turbo, but i've never looked into it either.
The TB's are definatly different. Turbos i 60mm I belive, and the NA's are 64mm. However since this is down stream of the turbo and the air is being forced past and through it, its not going to be a huge difference i would think. I wouldn't think it would be like an NA car where it will be able to get more air out of a larger TB because the turbo is already... bad word i guess... Limiting, or controling... the amount of air that is flowing into the intake by this point. larger and better flowing intake parts up stream of the turbo will also the turbo to grab more air to push in, but down stream it seems to me that it is already grabbed what it can and wont help much.
Then again... i could be completely wrong with this line of though...
Let us know if you try it out =)
Old Aug 12, 2010 | 12:48 PM
gilber33's Avatar
It won't fit. Look at them, two totally different units. Throttle cable vs drive by wire. won't fit/work.
87 740 turbo wagon
Feb 20, 2014 08:50 PM
dc_slim
Aug 27, 2005 03:31 PM
isons2004
Aug 9, 2005 05:47 PM
brushfires60
Jun 15, 2005 12:27 AM
jcmartin
Mar 3, 2005 12:02 AM
