windshield wipers
Old Dec 24, 2008 | 07:43 AM
dlenn's Avatar
Default windshield wipers
Hi,
My windshield wipers don't do a good job. It seems that they do not make full contact with the window. Any ideas?
Thanks,
Dave
Old Dec 24, 2008 | 07:53 AM
Psaboic's Avatar
Default RE: windshield wipers
Turn the wipers on, and then get them to stop/park in the nearly vertical position. Then you can carefully bend the arms so that the blades make better contact with the windshield.
Old Dec 24, 2008 | 08:23 AM
Adrenalin540's Avatar
Just a little more detail on Psaboic's post...
to stop em vertically just turn off the engine, then to bend the arm...go to the base right near the pivot point...and press towards the windshield that causes the entire assy to 'tweak' towards the winshield...I had to do mine last night, I was coming home from the Detroit Airport and the roads were crappy...then when I get closer to Toledo, my one arm loosens up.... luckily it was the passenger arm...today I am going to put some 'loctite on the shaft and on the nut...that will prevent this from happening again...
GL with your wipers
Old Dec 24, 2008 | 08:43 AM
JimKW's Avatar
To do mine I took the arm off and put it in a vise and bent it very slightly. I just made the existing bend a little more. I did very little thinking it would not be enough and I would just do more as needed being careful to not bend it too much. The first little bend was all it took.
Old Dec 24, 2008 | 11:18 AM
VJZ's Avatar
VJZ
Get new blades while you're at it.
You can get all three from CarQuest for $21.00 and some change. CarQuest stuff is awesome in quality.
dmg4
Jul 13, 2013 06:55 PM
westal
Nov 13, 2010 08:32 AM
MBo225
Jul 18, 2006 10:45 AM
jwilliam0414
Jun 9, 2006 06:16 PM
Yankee301
Nov 2, 2005 09:22 PM
