Wiring a 12V LOCK switch...
Old Oct 1, 2005 | 02:37 PM
rp850's Avatar
Default Wiring a 12V LOCK switch...
Hi,
I'm wiring up a lock switch for my dash and I've got some 14 gauge wire. Will that be safe and OK to use?
BONUS QUESTION: I know M- (unlock) is the yellow wire under the drivers side kick panel but where is M+ (lock) located??
Thanks
Old Oct 2, 2005 | 12:13 AM
Default RE: Wiring a 12V LOCK switch...
I would have to look at the diagram to help and I don't have one at home.
Old Oct 2, 2005 | 12:25 AM
rp850's Avatar
Thanks tech. I think M+ is the yellow wire with a brown stripe but I am not 100% sure. I was thinking of hooking up a voltmeter to it to see if voltage goes through when the doors lock. Is that the best way to test it?
Old Oct 2, 2005 | 12:32 AM
Thats how I would do it.
Old Oct 2, 2005 | 12:52 AM
rp850's Avatar
Thanks!
Old Oct 2, 2005 | 01:26 AM
NP
Old Oct 3, 2005 | 11:53 AM
rp850's Avatar
Hi,
One more question...Can you suggest a suitable place to splice into ground and illumination for this switch? There are two grounds on the switch - one for the lock power and the other for the illumination. Is it OK to just splice into the foglight switch for that? I figure it's right there. If there's some place easier and safer to do that just let me know.
Thanks!
Old Oct 3, 2005 | 08:57 PM
I beleive if you remove the drivers kick panel there is a ground setup under there.
Old Oct 4, 2005 | 01:02 AM
rp850's Avatar
By kick panel do you mean the drivers side undercover that's mounted under the steering column? I had that piece off this weekend and I don't recall any ground terminal under there. Then again, I'm not really sure what I'm looking for. Do I just look for a bunch of black wires all terminating in the same place?
Thanks!
Old Oct 4, 2005 | 08:38 PM
I think there is some wires to a screw.
Old Oct 5, 2005 | 02:38 PM
rp850's Avatar
Thanks I'll take another look.
Echoe
Aug 26, 2009 12:08 PM
Echoe
Engine & Internal
Aug 20, 2009 12:07 AM
carlog
Jun 30, 2007 11:23 PM
rjgspr
May 5, 2005 01:06 AM
rjgspr
May 3, 2005 10:54 PM
