would a 850R exhaust manifold to a 850AWD work well.
Old May 25, 2015 | 06:10 PM
mikeawd850's Avatar
Default would a 850R exhaust manifold to a 850AWD work well.
hi folks i was wondering, if the the fitment would be right? or would i be wasting my money.
Old May 28, 2015 | 10:51 AM
here's a thought - check if the 850 AWD (turbo right? the AWDs never came to the states until the V70 model so there's not a lot of info) and 850T share the same exhaust manifold - if so you can read up on interchange for the 850Ts where there should be more info. I recall there being something about the EGR port - but not sure which year/model that was for so look around the board on that topic.
Old Jun 4, 2015 | 05:04 PM
boxpin's Avatar
the manifold will work fine. What you need to watch out for is the EGR port. If you have one now, you need a manifold with one. If not, then you dont but the manifold is the same.
When I switched to an 'R' manifold I had to add an EGR port.
Old Feb 9, 2016 | 12:42 AM
mikeawd850's Avatar
i always forget to subscribe to my threads and i don't see when people comment.
anyway... since i have read your comment boxpin i have been trying to find out if my car has egr. is there a simpler way of going about finding it. i thought it would be behind my throttle body, but did not see anything there. is therew anothwer weay to tell? if my car has sas, would it alsi have egr?
Old Feb 9, 2016 | 11:12 AM
tryingbe's Avatar
Look for the EGR valve near the intake manifold.
Old Feb 9, 2016 | 12:18 PM
firebirdparts's Avatar
Under the throttle body, basically.
Old Feb 17, 2016 | 01:42 PM
boxpin's Avatar
If it is an 850R and not a 850 T-5R then you do not have an EGR. Meaning 96' or newer.
Old Feb 17, 2016 | 02:06 PM
mikeawd850's Avatar
97 850 AWD. i looked around the throttle body yesterday and i did not see a EGR. When i did the PCV a couple weeks ago i did not see it either. would a japanfold be better than the R manifold or they the same just differant makes for them?
Old Feb 24, 2016 | 02:44 AM
jdiding's Avatar
a real r manifold used is only about 130 bucks on ebay i have one sitting on my shelf for when i do my billet wheel 16t upgrade and exhaust
Old Feb 25, 2016 | 03:24 AM
mikeawd850's Avatar
the 16T upgrade from ARD was what i was planning to go along with the R manifold. Just have to find a 16T to rebuild. are you running any gauges aside from a boost gauge? any recomendations?
Fogducker
Jan 12, 2024 04:40 AM
jef59
Aug 5, 2015 08:14 PM
jorhyne
Jun 19, 2015 04:08 PM
Ivo
Dec 5, 2007 06:38 PM
bryanbloom
Mar 17, 2007 06:22 PM
