XC 90 outside mirror replacement
Old Apr 29, 2024 | 02:21 PM
Ricmax's Avatar
Default XC 90 outside mirror replacement
Need to know how to replace passenger side mirror replacement
Old May 8, 2024 | 08:02 PM
Niklas11Braun's Avatar
First, remove the plastic cover inside the door panel to reach the mirror bolts. Then, unscrew the bolts and disconnect any wires if your mirror is powered. Use a torque wrench to tighten the bolts properly. Make sure the mirror is aligned correctly before tightening the bolts. Lastly, reconnect any wires if needed and snap the plastic cover back on.
Also, you can watch online tutorials for your car model and mirror replacement process.
Ricmax
May 15, 2024 07:51 PM
fjp
Dec 4, 2021 07:16 PM
Kable646
Jul 8, 2013 01:53 AM
Nivekrg
Aug 27, 2009 08:59 PM
pharunk
Apr 3, 2008 10:26 PM
