Outside mirror glass replacement
Old Apr 29, 2024 | 02:13 PM
Ricmax's Avatar
Default Outside mirror glass replacement
Need to know how to replace just the mirror glass on the right side
Old May 8, 2024 | 01:22 PM
fred in florida's Avatar
My driver side just fell off my 2013. I just ordered a new mirror only. It is plastic and just has a peel and stick application.
Old May 15, 2024 | 07:51 PM
Niklas11Braun's Avatar
First, remove the old glass gently. You might need to use a hairdryer to soften the glue if it's stuck. After that, make sure the area is clean before putting on the new glass.
Check the backing plate for damage or dirt that could cause problems. If it's all clear, line up the new glass and press it in place.
Finally, wait about 24 hours for the glue to fully set before you start adjusting the mirror.
dece207
Feb 18, 2024 12:31 PM
Dee
Nov 14, 2023 12:15 AM
fjp
Dec 4, 2021 07:16 PM
Nivekrg
Aug 27, 2009 08:59 PM
RedTurbo850
Feb 28, 2007 11:02 PM
