Your Volvo 850 won't start??
Old Jan 11, 2008 | 12:40 PM
Volvo850GuyInMa's Avatar
Default Your Volvo 850 won't start??
I have a 1994 Volvo 850,non turbo 5 cyl. One day early this winter,after not having driven the car for 2 days, I thought I'd start it & let it run a few minutes to charge the battery,etc.
I let it run for onlya minute or so before shutting it down.
The next day I went to start it,& it just spun and spun,not catching or even trying to catch. It gave the impression of no spark,though I neglected to check for it. I decided (foolishly) that it must have been an ignition module,ECU,etc.
Come to find out,a wonderfully honest mechanic told me it had been in a flooded condition from not burning off the richer fuel from initial startup. He pulled the plugs & sprayed air into the cylinders to clear out the fuel,cleaned and dried the plugs,buttoned it back up & it started right up!!
I hope this may help some of you. I'm very grateful to the forum for helping me save a ton of money I just didn't have at the time...this is the least I can do...hope it helps!!
Dave
Old Jan 11, 2008 | 01:43 PM
info2x's Avatar
Default RE: Your Volvo 850 won't start??
Another remedy for this is built into the ECU.
[ol][*]Turn the key to pos II[*]Depress the gas pedal to the floor[*]Wait for 30 seconds (pedal still depressed)[*]Crank (key from pos II to pos III)[/ol]It takes about 30+ seconds but it seems to work like a champ.
On a side note you really shouldn't need to start the car every two days to charge the battery. I don't drive my car during the week and have never had a battery issue even in cold weather.
[align=left] [/align]
Old Jan 11, 2008 | 03:01 PM
phoenix_iii's Avatar
ORIGINAL: info2x
[align=left][/align]
info2x, is this to tell the ecu you are in a flooded condition, or what exactly is occurring?
Old Jan 11, 2008 | 07:17 PM
When it sees teh gas pedal all the way down it cuts the fuel off.
Old Jan 11, 2008 | 10:05 PM
info2x's Avatar
ORIGINAL: tech
exactly. Then as the engine rotates it pumps air through which allows the gas to vaporize to the point of ignition.
Old Jan 12, 2008 | 10:53 AM
Psaboic's Avatar
Good tip! Sort of like the way to start an old carburetor engine when it was flooded.
rspi
Aug 22, 2013 03:46 PM
slimflex2
Jun 13, 2013 11:36 PM
01_fast_ride
Dec 6, 2009 02:34 PM
boxpin
Nov 16, 2009 08:15 AM
bethanybreeze
Nov 8, 2006 09:31 PM
