2009 C30 Car keeps blowing Fuse 35
Old May 8, 2015 | 06:17 AM
usadventureracing's Avatar
Default 2009 C30 Car keeps blowing Fuse 35
Before I bring the car in to have someone look at the car I was wondering if anyone had any suggestion on why I keep blowing fuse 35? What can I check?
Thank you!
Old May 8, 2015 | 12:37 PM
Does it happen with any other event - ie turning on the AC or climate control blower? If you turn off the climate control/AC does the fuse stay on? If so, I'd suspect the AC relay is shorting. Look around for any sensor wires under the hood as well - anything chafing? When the fuse goes the car dies or run poorly etc???
Old May 8, 2015 | 12:43 PM
When I replace the fuse the engine is off and when I turn the car on with the air off and the fuse immediately blows.
Old May 8, 2015 | 01:16 PM
ES6T's Avatar
Probably needs an oil filter housing for a shorted PTC resistor.
Old May 18, 2015 | 06:39 AM
Got it fixed this weekend. The oil trap was shorting out.
jfltravel
Jul 10, 2019 10:33 AM
xc90mom
Jun 13, 2012 07:47 PM
tangox
Dec 29, 2008 01:27 PM
jdv999
Jun 3, 2008 05:37 PM
mrchuck85
Feb 28, 2007 09:08 PM
