2009 Volvo C30 Immobilizer. Try start again.
Old Aug 22, 2018 | 11:54 PM
daufoi's Avatar
Default 2009 Volvo C30 Immobilizer. Try start again.
I drive a 2009 Volvo C30. This morning I started the car and backed out of the garage. I needed to check something so I put it back in park and turned off the engine. After 5-10 minutes, came back to start the car and it wouldn't start. I got a message "Immobilizer. Try start again." I tried using the other key and still wouldn't start. I tried to start 3 or 4 times and each time sounded worse than the prior one. Please advise.
What else I have tried based on websites I found:
locked/unlocked the door 5 times in a row - nothing happened
leaving the ignition in position 2 for 5 minutes - cycles through all the error messages, says ABS is turned off, couldn't even lock/unlock my car using either the key or the car door anymore
disconnect the battery for 15 minutes - locking/unlocking back to normal, "Immobilizer. Try start again." after a few attempts to start the car
Old Aug 8, 2020 | 12:52 PM
Jack Steel's Avatar
Default Did you get this sorted in the end ? And how ?
did you get this sorted and how ?
Old Feb 26, 2021 | 09:56 PM
Trippychef's Avatar
Replace car battery should work had the same issue
April Marie
West
Mar 15, 2016 02:50 PM
coalnation
Volvo C30
Sep 10, 2014 02:36 AM
dan_beaven
Volvo C30
Dec 9, 2013 07:38 PM
crystalfleet
Jan 16, 2008 07:30 PM
