check engine light - blown fuse - error codes. Problems.
Old Jun 24, 2018 | 01:41 PM
j-oregon's Avatar
Default check engine light - blown fuse - error codes. Problems.
I have a Check Engine light on accompanied by a blown fuse. I attached an OBDII reader and found the following codes. Has anyone else seen this type of problem? Seems like there is either a faulty part or a short. Found blown fuse F35 and cleared the codes but a day later the fuse blew again. I recently had the brakes checked but no other recent work.
Symptoms: when starting, the car no longer idles high for ~30 seconds before settling in. I do hear what sounds like a chirping sound in the vicinity of the alternator, though I don't know if that sound is new. Seems like less power and lower gas mileage. Someone in another thread said that was a sign of oil trap problems? I'm not driving it much. Probably have put on about 40 miles since the problem started.
Any help is definitely appreciated.
Blown Fuse: f35 - engine management
P0445 Evaporative emission system purge control valve circuit shorted
P0442 Evaporative emission system leak detected (small leak)
P0079 Exhaust valve control solenoid circuit low
P2401 evaporative emission system leak detection pump control circuit low
P0497 Evaporative emission system low purge flow
P0102 Mass or volume air flow circuit low input
P0245 Turbo/supercharger wastegate solenoid "A" Low
P0076 intake valve control solenoid circuit low
P2419 Evaporative emission system switching valve control circuit low
Old Jun 25, 2018 | 04:01 PM
ES6T's Avatar
You probably need a new breather box
Old Jun 28, 2018 | 09:50 AM
j-oregon's Avatar
is this the right part?
Amazon Amazon
Old Jun 28, 2018 | 11:37 AM
ES6T's Avatar
Yep. See that electrical connector? That's a heating element that gets shorted and pops the fuse. You can disconnect yours in the meantime if you'd like.
Old Jun 28, 2018 | 12:06 PM
j-oregon's Avatar
Good to know. Can you confirm that I would need to drain the oil before replacing this part? I read that somewhere but wasn't sure if it was true.
thanks!
Old Jun 28, 2018 | 12:51 PM
ES6T's Avatar
You do not need to drain the oil, but some will come out. Loosen the filter to allow the housing the drain into the block as much as possible. The housing comes with a new filter so good time to change the oil as well.
Old Jun 28, 2018 | 12:52 PM
j-oregon's Avatar
thank you for the info, I really appreciate it!
quick6black
Jun 11, 2018 05:01 PM
john gill
2001-2013 model year V70
Apr 21, 2018 01:23 PM
Pubcha
Mar 14, 2014 11:01 PM
habbyguy
Feb 20, 2014 06:20 PM
quick6black
Dec 18, 2010 05:20 PM
