trigger wheel
Old Feb 17, 2016 | 03:30 AM
sonyII's Avatar
Default trigger wheel
what kind of crank trigger wheel is C30 using
Old Feb 17, 2016 | 10:36 AM
not sure what you mean by crank trigger wheel. Do you mean the crankshaft position sensor which tells the ECU where in its rotation the crankshaft is? The CPS is a hall effect sensor - where a permanent magnet is swiped by a coil in the sensor to read the position. The CPS should be somewhere by the transmission on the C30 (reading off the flywheel??) but you can probably find a video on Youtube to help locate it.
shanewilsonjr
Aug 1, 2015 04:07 AM
trainlover
Mar 16, 2014 08:48 AM
JerrySC
Nov 19, 2012 07:56 AM
ibified
Sep 1, 2011 02:33 PM
ADStang
Nov 7, 2010 06:18 PM
