1999 C70 Engine Swap
Old Feb 28, 2009 | 01:26 PM
Ayalamarc's Avatar
Question 1999 C70 Engine Swap
New to the forum. I have found great info in the past. I'm wondering if anyone would know what model year engines would be usable in my 99. I have the T5 2.3 Turbo (B5234T3). My current engine is on it's last legs and would like to know if a newer model would work. Possibly I could find a lower mileage engine from a newer year.
Thx!
Old Feb 28, 2009 | 01:41 PM
I know the 99 and 2000 motors will work but not 100% sure about the 01 and up motors.
Old Mar 1, 2009 | 11:42 AM
reg's Avatar
reg
TECH, isn't year 2001 the year Volvo changed to the Italian ETM? If so, I would think that that would be the only issue as the block, valve train, and etc would be the same since God was a corporal. With that stated, I should think that any short block that aylamarc found would suffice and only the induction would have to be used from his old engine.
r.
Old Mar 1, 2009 | 12:28 PM
Well there is alot of other things throw in there. One is the VVT setup. In 99 they started VVT. Also another one in there is solid verse hydrolic lifters.
Mainly the blocks stayed the same it was the heads that changed.
Old Mar 2, 2009 | 04:50 PM
reg's Avatar
reg
So perhaps he could re-use his head and induction?? He did not indicate what was giving up on his engine.........I simply surmised that his bottom end and rings were probably shot.......... By the way TECH, it was 20 degrees below zero in Minnesota this morning. Florida ain't so bad, eh what?
reg
Old Mar 2, 2009 | 08:40 PM
Florida was about 36 here this morning.
Sounded like he just wanted a new motor to refresh the car.
Old Mar 14, 2009 | 02:58 PM
Ayalamarc's Avatar
Thanks for the info. The motor is on it's last legs. I think it's the bottom end that's about to go. I'll expand my search beyond 99 in hopes that the head can be swapped over. Reg and Tech, thanks!
Archive5150
Aug 24, 2015 09:24 AM
securisign
May 31, 2014 11:10 AM
Surferwhale90
Nov 28, 2012 06:36 PM
hufilm99
Oct 8, 2011 10:17 AM
kendog68
Feb 28, 2010 09:36 PM
