Convertible top not going down
Old Mar 6, 2009 | 02:39 PM
merlinx's Avatar
Default Convertible top not going down
Hi Guys I have a 2004 C-70 and its been cold all winter. Today was warmer and I tried to put the top down with the p brake on and the car stopped and the top would not go down but the little orange light would blink. When I turned the car on the top worked fine and the light did not blink but when I started the car the top stopped working. Even if I stopped mid way and turned on the car. If I killed the engine and left the key in the on position it worked again. Anyone have any ideas?
Old Mar 6, 2009 | 08:13 PM
There is codes stored in the system that need to be cleared.
Old Mar 6, 2009 | 08:38 PM
merlinx's Avatar
Can you just use an OBD 2 to read and reset the codes? Why do you think the top works when the engine is off (the light does not blink then)
Old Mar 6, 2009 | 08:50 PM
No a special setup is needed.
I believe that is the programming in the computer.
Old Mar 6, 2009 | 08:58 PM
merlinx's Avatar
Tech, do you know how to check the codes stored in the system and how to clear them? What do I need to do? Or are you saying I need to take it to the dealer?
Funny thing is it was working fine last summer.
Old Mar 6, 2009 | 09:01 PM
You will need to take it to a Dealer or Volvo specialist shop that can read them.
Old Mar 13, 2009 | 05:57 PM
merlinx's Avatar
Has anyone ever had this problem? would take it to the dealer but I dont want to pay $125 for them to just plug it in a computer. It seems like it would be some sensor.
Old Mar 13, 2009 | 08:54 PM
Johnny Mullet's Avatar
Even if it was a sensor, only the Volvo diagnostics can find it.
Old Mar 14, 2009 | 07:15 AM
Tim_Baker's Avatar
Default Same problem
I am having the same problem, did you get it fixed?
Old Mar 16, 2009 | 10:41 AM
merlinx's Avatar
Smile
Ha!!!!
I found the problem hopefully this will help others. For some reason the parking brake light want coming on when I applied the P brake, it would come on intermittently. When the car ignition was on with the motor off all the lights were on so the top worked. I just took out the P brake handle cover and played with the switch and now it works fine. Almost went to the dealer.. that would have been a waste of $125 at the least.
adamstatonsmith
Dec 19, 2022 10:41 AM
caraita
May 24, 2014 11:32 PM
jldriggers
Jan 27, 2012 10:55 PM
robert lickley
Jan 16, 2011 11:49 PM
Business_Socks
Jan 7, 2009 04:05 PM
