1999 C70 Keyfob/Central Locking issues
Hi everyone
Sorry if there's a similar thread somewhere, but I couldn't find one.
My C70 (1999 2.4GT, V-Reg) came with one remote fob that had a flat battery. I've changed the battery but the fob still doesn't work. I've tried the "switch on & off 5 times then press the remote lock" process but that doesn't seem to do anything either, so I now have a couple of questions...
1. Is there any way to test if the keyfob is actually transmitting a signal?
2. If I buy a replacement keyfob on eBay (with the correct part number) will I be able to program it using the above sequence, need to take it to a dealer or just be wasting money (some posts I've seen say that used fobs can't be reprogrammed)?
3. If it needs a dealer reprogram, any idea as to the cost?
4. Would I be better off forgetting the original keyfob and buying an after-market alarm with remote locking?
Just as an extra, the little light in the centre of the dashboard (I assume it's for the alarm) doesn't come on; ever, so I assume the alarm isn't activated
Sorry for all the questions!
Thanks in advance for your help.
