2000 C70 manual shift knob replacement
Old Nov 12, 2016 | 11:40 AM
Blade's Avatar
Default 2000 C70 manual shift **** replacement
Trying to replace the worn shifter **** on the 2000 C70 manual, can't seem to get the old one off, neither could I find instructions specific to this model. Anyone with instructions or any hints? I got the boot pulled up but unable to remove the **** itself. Thank you!
Old Nov 12, 2016 | 12:02 PM
Blade's Avatar
I knew soon as I would ask this question I would figure it out too.
If anyone needs it here are the instructions: pry off the boot from the **** with a flat screw driver, that exposes the base of the ****, couple of clamps holding the **** to the shaft, pry just one up and the **** will pop off.
matt01
Apr 6, 2014 04:31 PM
Pmauch
Feb 22, 2011 06:46 PM
litehwk356
Oct 4, 2008 08:20 PM
jfspring
Jan 29, 2006 12:00 AM
jcmartin
Sep 20, 2005 08:54 PM
